Spohn vs BMR
Old Apr 2, 2005 | 11:32 PM
1972chevelle454's Avatar
Default Spohn vs BMR
I am looking into getting some tubular SFC's, LCA's, Panhard Rod and Relocation brackets. Would you guys reccomend either bmr or spohn. Which would you guys reccomend more? Where is the best place to pick this stuff up from?
Old Apr 3, 2005 | 12:48 AM
Turo's Avatar
Im no expert, but I doubt there would be a whole lot of difference between the 2, as long as you compare similar products. I run chromoly Spohn lca's and BMR lca brackets, both are great.
Old Apr 3, 2005 | 12:09 PM
ttt....
Old Apr 3, 2005 | 05:27 PM
UMD_Jesse's Avatar
From: Fairfax County, VA (You know you're here when you see the bad roads)
I believe Spohn uses a larger diameter tubing, so I would think they might be stronger. Both companys have good reputations.
