Broken Torque Arm!!!!!
Thanks for your replys in advance
Roy
I just did it myself about a month ago...
The Moser rears utilize 4 short bolts to secure the torque arm to the rear housing...the problem is that the bolts can vibrate loose, it may not be noticeable during normal driving, but when you go for that one hard launch bam the arm moves and breaks by elongating the holes.
Strange 12 bolts and 9" utilize two LONG bolts exactly like the stock rear does
When you get a new torque arm make sure to red loctite the bolts and you can even safety wire them to each other so they don't loosen up again.
Also, since your new arm will be much thicker then the stock arm you should get bolts that are a tad longer.
Try searching through the sponsors----->
I'm not sure exactly who may sell it
