How much do a few mods really help?
Old Apr 21, 2005 | 06:00 AM
nikkev's Avatar
Default How much do a few mods really help?
1998 Camaro Z28 A4
I am trying to diagnose an engine stumble so I am trying to see where my car is power wise. I KNOW you need traction to go faster, so don't think I'm retarded for asking this! I just put 3 new suspension mods on my car:
- Edlebrock Torque Arm (the new style, not the one with breakage issues)
-BMR LCA relocation brackets (I put the LCA's in the lowest hole)
-Eibach lowering springs
My rear tires are 285 Pirreli's and before my stumble I could punch the car at 30mph and break the rear tires loose and get sideways. Now when I punch it, the car might break the tires loose a little, but not like before. So, am I down on engine power, or did those 2 little mods help my suspension on the street?
PS
If the traction control is turned off, will you get a low traction light if you lose traction? Or will the light only illuminate if the TCS is turned on.
EDIT:
Forgot to add some info:
My total suspension:
24mm rear swaybar
Hotchkiss panhard rod
BMR LCA's
TA cover/stud kit
Eibach springs
BMR subframe connectors
no front swaybar
BMR strut tower brace (used to replaced my front swaybar and it weighs less!)
LOL, can you tell that I am working my way forward??!!
