Got An Official Opinion!
Right now all I have are BMR SFC's and STB, and a Tunnel Brace. The front of my car is 6 inches from the ground due to the front gfx, and the tunnel brace is around 4 inches off the ground at the transmission. This car will probably never see the track, but I would like to do some suspension work, lowering a little if possible, for daily driving just to make the ride a little more enjoyable and to complement my 19's. What would you all suggest? My ground clearance has me worried on shocks/springs b/c I still want to be able to drive it. I would like to do away w/ wheel hop also in case I do venture out to the strip. Thanks.
What Sam Strano said:
Chris,
I'd recommend the Koni shocks to you. First, you'll see a HUGE improvement in the way the car rides and drives. But also important in your case, they allow you to lower the car slightly while keeping the stock springs. The result is you don't end up slammed on the ground, or with a brick stiff ride.
The use of the Koni's to lower will drop the front of the car about 3/4", and the rear approximately 1/2" or so. Beyond this option, you are into a minimum of 1" drop springs, which do cause problems with cars that have the ground effects.
Pictures of the car can be seen here:
https://ls1tech.com/forums/wheels-tires/308363-19-evo-s-sgm-ss.html
What do you all think?
btw sam's a good guy to deal with, great service and prices
The rear is simple. Just remove the isolator and put a section of heater hose on the top coil of the spring (to act as an isolator) and that will lower the rear.
Piece of cake.
Piece of cake.
.Trackbird-can you post a pic of the *perches*?
I don't have one, sorry. I'm running Koni DA's and they don't get the second "perch" location in the front, just the SA's. If you look at any front shock from a 4th gen, you'll see a "snap ring" that the mount for the spring sits on. The Koni SA's have two slots for that ring. The top one is stock height, the second one (roughly 3/4", give or take) lower on the body will lower the front of the car.
