knocking
Old Apr 29, 2005 | 08:25 PM
TNC_LS1's Avatar
Default knocking
dont know if this is the right section...but there is a knocking in the rear around the right tire it sounds like a bar or something hitting the floorboard and it only happens when i hit a bump or something. ive crawled under there and didnt fine anything loose but didnt really no what to look for so...i was wondering where to start and what all to check????
and could shocks cause this????
its driving me crazy..
thanks in advance
Old Apr 30, 2005 | 05:21 PM
TNC_LS1's Avatar
thanks in advance
nobody on here can help me???
Old May 1, 2005 | 01:16 AM
chupr0kabra's Avatar
I would check:
1) Lug nuts
2) Panhard rod bolts (upper and lower, and jam nuts if you have an adjustable)
3) Lower Control Arm bolts
4) Shock bolts
5) Springs (make sure they are centered and on the isolators)
6) Brakes (doubtful)
-Mike
Old May 1, 2005 | 01:35 AM
felton316's Avatar
Right rear? I would check the Borla 'over-the-axle' pipe, make sure its not hitting anything.
