Handle This
Old May 4, 2005 | 10:56 PM
FormulaFire's Avatar
Default Handle This
I want to build my 99 TA WS6 6 Speed to handle the power of the procharger D1SC. I plan on putting down 550-600rwhp. I will already be getting the Moser 12 bolt. What Suspension parts will I need to put this power to the ground. Please tell me what to get.. HELP!!!
Thanks,
Justin
Old May 5, 2005 | 11:08 AM
~JOSHUA's Avatar
High performance valve stem covers...
Honestly you need it all. Subframe connectors, lca's,panhard ,relocation brackets, sway bars,torque arm, ds loop,strut tower brace,performance bushings.
Take your pick and pay as you can... good luck!
Old May 5, 2005 | 01:59 PM
I figured I would need it all. Is this stuff hard to install?
Old May 5, 2005 | 02:30 PM
~JOSHUA's Avatar
Yes and no...
Old May 5, 2005 | 04:01 PM
Will this "Trak Pak" give me everything I need to put in the BMR Torque Arm and relocate it off the Transmission? Has anyone bought this?
http://www.bmrfabrication.com/F-body...htm#torquearms
Old May 5, 2005 | 04:24 PM
~JOSHUA's Avatar
Do you subscribe to GMHTP? They did an article about 4 months ago where they put EVERY BMR product on the car in one day. Might want to find that article called " Stab Stall and Shift".
I don't know if that torque arm bolts to the trani or the frame. Maybe someone else will chime in.
