installed adjustable lca's and phb
Old May 16, 2005 | 11:10 AM
105's Avatar
105
Default installed adjustable lca's and phb
I just installed my BMR adjustable lca's and phb. It took about 3 hours. The only part I'm not sure about is the adjustment on the lca's. once they are on you can adjust them to pull the rear forward or push it back. how will this affect the performance? I made them the same length as stock but ended up having to measure both sides to make them the same once on.
Old May 16, 2005 | 10:11 PM
OldeSkool's Avatar
eh, it adjusts the thrust angle... if its off, the car will "crab" not a huge damper on performance i dont think, unless its WAY off... the thing i'd be more concerned about is tire wear, but still, not sure how much thrust angle is going to affect that.
Old May 17, 2005 | 07:33 AM
105's Avatar
105
thanks
