Bottoming Out ?
1) Could I be bottoming out (at my power level) ? If so,
- what would be a cheap fix?
- what would be the best fix?
If I'm not bottoming out, what do you think the massive clunk I hear and feel is ?
Eventually, like in a year or so - I want heads/cam/clutch/rear end - 450 RWHP.
Thanks for any help!
You have a few choices.
A cheap fix, would be to increase the rear spring rates.
A really cheap fix would be to add one or 2 metal spacers to the rear springs. The downside is that it will increase the rear ride height a little. http://gmocart2.gmotion.com/store/me...ing_suspension
Install 2 of these in each rear spring. Just lift from the body to get the springs in full droop, install in the middle area 180* apart making sure they will not rub the body. Check the ride height. The weight of the car will keep them in place. Try them for a day. Do a few launches. If the problem goes away, you found the culprit. If the lift is too much, take one out. They work great, just get the smaller sized ones that says for the front. Just ignore that as they work fine on the rear springs. If after all that, you still don't like them, take them out and you will be $5 poorer. No big deal.
A more costly fix might be to move to some better rear shocks. The factory ones are way too soft and have trouble controlling the cars body movements.
Take a read.
https://ls1tech.com/forums/suspension-brakes/315910-loud-hard-clunk.html
