Custom panhard bar?
I want an aftermarket diff cover put on, but they are all thicker than stock, and my panhard is only 1/2" from the stock diff cover. So basically what I need is an aftermarket panhard bar made that bends around the diff just like a sway bar might.
Anyone know of a place that does this kind of fab work?
v (diff) v this way instead of this way.. v (diff) v
l____________l ----\___/----
(the v's are the mounting locations)
That way it will give you clearance and you wont have a bent section in the middle of the panhard bar. you can 'bend' out the ends and gusset them and so forth and have a plenty strong piece
