APHB installation question
Old Jun 4, 2005 | 12:13 PM
9silverbird8's Avatar
Default APHB installation question
I just got the single adjustable PHB from LG and was wondering how I should install it. Should I put the rod end on the chassis or the axle? Also any tips for when it comes time to adjust it?
Old Jun 4, 2005 | 06:14 PM
2001NBMZ28's Avatar
Strength wise it shouldn't matter - I'd put the rod end on the chassis, just cause it's out of sight. Mine has adjustments on both sides. Just measured the stock holes center to center, adjusted the new one to the same specs and installed it. If you lower your car or need to adjust it take a look at BMR's site, they have detailed install instructions.
Old Jun 4, 2005 | 07:56 PM
JasonWW's Avatar
Put some loctite on the bolts. They like to come loose.
ssPetess's Avatar
Put the rod end on the axle side. The poly bushing will lessen the vibrations to the body when installed on the body side.
on the loctite, mine came loose...
Old Jun 4, 2005 | 08:01 PM
right on guys, thanx
