QA1 Installation Question.....
Extremly easy install. You will need to pick up some grade 8 nuts bolts and washer for the two lower mounting points in the rear. You'll need like 6-8 washers total to space the shocks away from the rear since they might hit.
Edit: If I use Locktite, should I use it on all the bolts or only certain ones?
