Caliper Guide Pin
Old Jun 15, 2005 | 11:48 AM
Blacker's Avatar
Default Caliper Guide Pin
What type of grease would be used on the caliper guide pins? I have Marine and White Lithium in my tool box or should I use something else?
Old Jun 15, 2005 | 01:56 PM
Fulton 1's Avatar
At the autoparts store - usually in the aisle near the RTV's - you will find brake caliper-specific synthetic grease/lube. The stuff I use is made by Permatex and it's called Ultra Disc Brake Caliper Lube (green in color) - it usually comes in little "packets" that you tear open or small bottle as shown below.
Old Jun 17, 2005 | 11:49 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
Similar topic different question....
Does anyone know where to get new brake caliper mounting brackets? I have a guide pin that is seized, i.e. not free moving like it should be.
Anyone?
Old Jun 17, 2005 | 11:55 AM
JasonWW's Avatar
It would be risky to get a used one. I would just get a new one from the dealer or GMParts.com.
Old Jun 17, 2005 | 12:11 PM
UNDER PRESSURE MOD
Well, I tried locating the part number using gmpartsdirect.com and couldn't locate it, that's why I put up a post asking for a part number.
Anyhelp would be greatly appreciated.
Old Jun 17, 2005 | 12:26 PM
trackbird's Avatar
The last one I bought (for a grand am, but similar if not the same part) came from my local dealer.
Old Jun 17, 2005 | 12:37 PM
JasonWW's Avatar
Ohh, you didn't ask about the part number. Can't you just call? You want me to call for you and get the number?
Old Jun 17, 2005 | 12:43 PM
UNDER PRESSURE MOD
Thanks Jason but I used the search function (should know better by now) and found it.
It's 18026163, in case anyone else is interested. GM Parts Direct has them listed at $58.92 (damn), but with shipping it's closer to $70.00. Oh well, it needs to be done right.
Old Jun 17, 2005 | 01:02 PM
JasonWW's Avatar
Out of curiosity, is that the front or rear number and do the left and right sides use the same piece only flipped over?
Old Jun 17, 2005 | 01:24 PM
mitchntx's Avatar
I bought guide pins for my race car from O'Reilly's
And they came with new seals and grease.
Old Jun 17, 2005 | 01:28 PM
JasonWW's Avatar
Originally Posted by mitchntx
I bought guide pins for my race car from O'Reilly's.
I think we are talking about the caliper brackets, not the guide pins, right?
Old Jun 17, 2005 | 04:38 PM
UNDER PRESSURE MOD
Yeah, I'm talking about the caliper brackets. And yes, that is the number for the fronts and they are the same left/right.
I've found that you need to inspect them on a pretty regular basis especially if you do any high speed breaking that puts a lot of heat into the brakes. The grease can actually harden and become more of an adhesive than lubricant. I actually had this happen a couple years ago and snapped the pin trying to remove it.
During my search, I found someone who had luck removing it by hitting it with a torch to break the pin loose. Oviously you will need a new rubber seal at that point.
Hope I've added to this thread after taking it off topic...LOL
Old Jun 17, 2005 | 06:21 PM
ActionJack's Avatar
FWIW
I had to replace the bracket and 2 pins. GM charges way too much for these parts IMO.
I have been using the synthetic grease since. So far no more issues. And, it is about time to check them...
Old Jun 17, 2005 | 07:24 PM
76LS1BIRD's Avatar
Restricted User
the C-5 bracket is only $32 here
http://www.superchevyperformance.com...s/c5brakes.asp
they mite have F-body cheaper. ?
Old Aug 1, 2005 | 06:23 PM
Bluehawk27's Avatar
I know i'm late in replying to this, but it could help someone else. I just removed the boot, and hit that bad boy with a torch. It slid right out. I cleaned it off, lubed it and put it right back in. It works perfect now, but then again it was working great before hand too. Only reason i found it was siezed is cuz i was doing a rotor/pad swap.
