Panhard opinion
Old Jun 17, 2005 | 04:42 PM
aNuBiS's Avatar
Default Panhard opinion
Well anyone who hasnt got one but has thought about it. I just did it in a gravel driveway on my back with minimal tools in no time. Its a huge difference just in look compared to the stamped steel stock peice. Have a look and tell me which one you would choose. Now go get one.
Old Jun 17, 2005 | 07:56 PM
MeentSS02's Avatar
Kleeborp the Moderator™
I like the looks of the one in the top of the picture. I'd take that one.
Old Jun 17, 2005 | 09:17 PM
aNuBiS's Avatar
Hahah, then my work here is done!
Old Jun 18, 2005 | 02:40 AM
DONAIMIAN's Avatar
I have a rod ended one that im looking to upgrade to the LG version soon. The one on there now had the cheap rod ends.
Old Jun 18, 2005 | 06:42 AM
MeentSS02's Avatar
Take it from somebody that's been down that road...no matter what kinda rod end you use, it will eventually end up rattling.
Old Jun 18, 2005 | 08:11 PM
JasonWW's Avatar
Just replace your current rod ends with good ones. Why would you need to replace the bar itself?
Old Jun 18, 2005 | 08:14 PM
JasonWW's Avatar
What rod ends did you try?
Are you talking about the PHR or the LCA's? There is a big difference between the two.
Basically your right. Eventually all rod ends will rattle because they are wearable parts. They need to be replaced as they wear. Weather they last 2 months or 2 years depends on the quality.
Old Jun 18, 2005 | 08:50 PM
DONAIMIAN's Avatar
paint is peeling and its starting to rust and what not. Im either gona replace it, or take it somewhere and get it powdercoated again.
Old Jun 19, 2005 | 10:24 AM
aNuBiS's Avatar
Nice color paint on your car btw.
Old Jun 19, 2005 | 04:16 PM
MeentSS02's Avatar
I did some cheapos, and then I did QA1s on both the PHR and LCAs. The LCAs rattled the most (obviously), and they were LG poly/rod units. Both the LCAs and the PHR rattled after one month of driving (it is my daily driver, but only sees about 250 miles a week at the most).
I must say that I'm not willing to try rod ends again unless I'm going to the track. They just start rattling too fast for my liking. So I'll keep my poly/poly pieces in the car, and enjoy a nice, quiet ride. Hell, even my LG torque arm is rattling after three months. It is next to go...
Old Jun 19, 2005 | 04:32 PM
lilstephsls1's Avatar
CT Hotness
i just installed my phr this weekend and drove it today with a new torque arm...what a difference
Old Jun 19, 2005 | 06:12 PM
trackbird's Avatar
I've run many types of rod ends on my PHB. I tried a BMR PHB with the "cheap" teflon lined ends that were on it. It wasn't too noisy (the LCA's sure were though). I built a prototype with non lined rod ends. The ends would rattle when you shook them in with your hand (like a baby's rattle), but they were not too noisy (though they should have been). I then went to the QA1 XMR series (LG Motorsports can order them for you) and they are silent, even after street use and several autocross events. The PHB makes no noise, none.
LCA's are much more picky about worn rod ends than PHB's are. I'd still suggest a good quality PHB with rod ends, even for street use.
Old Jun 19, 2005 | 08:03 PM
mitchntx's Avatar
I post that and I'm cheer leading, even though it is the God's honest truth.
My LGM PHB with rod ends have been on the car for 2 years and my LGM poly/rod LCAs have been on the car for 4 years.
At slow speeds and a washboard road, I am just now beginning to detect some noise, as long as the radio is off and windows are rolled up with no AC blower running.
Old Jun 20, 2005 | 10:36 AM
trackbird's Avatar
I'm trying to reduce your workload.....
Old Jun 20, 2005 | 12:29 PM
mitchntx's Avatar
Don't worry about MY workload.
I am tired of dealing with egos and igmos ...
Old Jun 20, 2005 | 02:36 PM
sb427f-car's Avatar
SSU'S Vice Mod
Mitchntx and Trackbird...you two are the handeling breaking gurus, and I've yet to ascertain what the rod ends gain you. Does it keep things from binding as bad and allow for more adjustment in adjustable LCA and PHR? I'm the kind of person that can live with noise for improved performance.
Old Jun 20, 2005 | 03:24 PM
JasonWW's Avatar
Rod ends help a lot on the LCA's.
The factory rear suspension is a type of 3 link design. When cornering the LCA's move up and down as well as twist. They are supposed to twist, you can't get around that.
So what the factory does is use a U shapped sheetmetal arm along with big rubber bushings to allow the twist.
Poly bushed LCA's are so much more rigid that when they try and twist, they end up binding which makes the arms not want to move up and down smoothly. Under these conditions it makes the rear feel like the springs suddenly got a lot stiffer and that causes the rear to get loose.
Having at least one rod end will alleviate that twisting bind and allow the LCA's to move up and down smoothly like they are supposed to.
This relatively new design Jon A came up with is supposed to be the best of both worlds. If I ever get the money for LCA's, I'm going to make a set like this.
As far as rod ends on the PHR, they mainly get rid of the slack which makes the rear more solid feeling and less sloppy.
Old Jun 20, 2005 | 05:06 PM
mitchntx's Avatar
Define "relatively new" ... I've had LGM poly/rod LCAs on my TA for 4 years.
All Jon did was incorporate a screw in poly bushing ... innovative maybe, new ... I don't think so.
sb427f-car I appreciate the vote of confidence.
However, I do not consider myself an expert ... far from it, actually.
I'm too old and set in my ways to argue details of a personal setup. What I might tell you which works for me, would absolutely suck when installed on your car.
That's why there are 2 camps when it comes to rod ends. Many have had a single bad experience and therefore proclaim all are noisey. I realize there are exceptions and they are duly noted.
The only advice I will give is for you to find a vendor willing to give you a money back guarantee. If they are noisey when you put them on, you get your money back.
If a vendor stands behind their product, proclaiming they are "the best" then they should by God stand behind them. And typically a vendor that builds and tests the stuff will do this. Resellers and drop shippers won't.
If they refuse, move on.
Give LG Motorsports a try or UMI Performance. I am sold on LGM for superior products and standing behind them and am impressed with Ryan's (UMI Performance) willingness to take constructive feedback to amke improvements in their products.
Old Jun 20, 2005 | 06:57 PM
sb427f-car's Avatar
SSU'S Vice Mod
UMI stuff has my eye. From what I've read and the looks of their products, it does look nice and they aren't that far away from me either (MD vs. PA) so if I ever need something, it'd be worth a drive.
Old Jun 20, 2005 | 08:17 PM
JasonWW's Avatar
Look again Mitch. That is a thin rubber bushing, not poly. It's able to soak up the vibrations while not creating a lot of slop.
(It is imperative they be torqued with the suspension loaded, as you can imagine)
Jon talks about them here:
http://frrax.com/rrforum/index.php?act=ST&f=3&t=3553&
