Play in steering response.
Old Jun 28, 2005 | 01:16 AM
Rare96WS6's Avatar
Default Play in steering response.
Is it the tie rod ends being worn that causes a car to have play in the steering wheel? When I turn the wheel, it has play from side to side before the car actually turns.
Old Jun 28, 2005 | 02:18 AM
pimpmaro's Avatar
Not necessarily, there are several factors that can cause a car to have "play" in the steering wheel. Even the car's alignment can have an affect on how responsive it is to steering wheel inputs.
Old Jun 28, 2005 | 03:34 AM
DONAIMIAN's Avatar
I think its the common F-body dead spot. Next time you get an alignment, get then to put a little more toe out on the front end, should make things more responsive.
Old Jun 28, 2005 | 11:06 AM
Charging TA's Avatar
Could the rag joint cause this?
Old Jul 1, 2005 | 11:14 AM
Rare96WS6's Avatar
Well, the rubber that protects the tie rod ends are cracked, so they are not sealed good. I thought it might be them causing the play. The make a creaking and popping noise when I steer the car. At least i think this is what is making the noise. I have new ball joints, and a arms. When getting it aligned again with the new tie rods, if I do end up needing to give the car a little toe out, won't that wear the tires quicker or incorrectly up front? Can a worn steering shaft also cause the play?
Old Jul 1, 2005 | 01:52 PM
VIP1's Avatar
Copy & Paste Moderator
If the tie-rods are noisy, they are worn.
Here are some threads on alignment:
https://ls1tech.com/forums/showthrea...ight=alignment
Some general info about alignment and terms:
There were many more threads....but I figured you'd get the idea from these. The first few threads I posted contain the specs that many on here use.
Old Jul 4, 2005 | 08:33 PM
Rare96WS6's Avatar
Thanks!
