edelbrock torque arm
Old Jul 1, 2005 | 12:12 PM
Magnet's Avatar
Default edelbrock torque arm
what would the benefits of a torque arm be? found a good deal on one and nwas wonderin what its actually goona do........sorry i have stupid questions
Old Jul 1, 2005 | 12:46 PM
Magnet's Avatar
aynybody? im new to the suspension stuff dont know what im doing....i tried to search and all i got was people saying they broke theirs and discussion between adj and no adj. so i dont know what they do haha
Old Jul 1, 2005 | 12:56 PM
mcowart's Avatar
they plant ur rear tires for traction and help reduce side ways movement on a hard launch
Old Jul 1, 2005 | 01:04 PM
Magnet's Avatar
sweet so it will help traction? is it a noticable difference?
Old Jul 1, 2005 | 01:09 PM
2xLS1's Avatar
The tq arm runs from the center of the rear end to the tailshaft of the transmission. It keeps the rear end from rotating in the opposite direction that the tires rotate and sets the pinion angle at a certain position. The stock tq arm is stamped steel and supposedly could flex under loads. Aftermarket tq arms are usually made of tubular steel with X bracing to resist flexing. The Edelbrock tq arm is non adjustable as far as changing the pinion angle from it's fixed setting. Other A/M tq arms that are adjustable will allow you to change the pinion angle setting. Some even move the front mounting point from the tailshaft of the tranny to the body or floorpan of the car.
Old Jul 1, 2005 | 01:11 PM
mcowart's Avatar
haha.. i guess so, i broke mine so it went from one extreme to the other....but i would think that there is a difference..when u compare the stock TA to an after market one side by side, there is a noticable diff. in strength
