Sway Bar
Old Jul 3, 2005 | 05:57 PM
asudecat's Avatar
Default Sway Bar
Can someone please inform me on a good sway bar to get. I have found a 35mm front and 25mm rear but a guy told me 25mm for the rear is too much.
I also found a 36mm front.
Do I just need a front or just a back or both or what.
I will have around 500hp + 250 shot. Daily driver maybe 10 times at the most a year at the track. I just want some improved handling. please help thanks.
Old Jul 3, 2005 | 08:07 PM
CamdLs1's Avatar
Strano has a good one at stranoparts.com, 35mm and hollow which means it weighs 17 pounds instead of 40. Where did you see a 36mm?
Old Jul 3, 2005 | 10:08 PM
Judd's Avatar
I believe that Hotchkiss and SLP have a hollow 36 mm front bar {might be the same}, it's big money though.
The 25mm would most likely be too stiff. If you are wanting to do this cheaply, a ST 35mm solid is fairly cheap {something like 140 bucks I think} and keep the factory 19mm rear, works well for most people. If you are still wanting more bar in the rear, try a solid 21mm. They are fairly cheap also.
If you don't mind spending more money, try the bar that CamdLs1 recommended. I have it and I like it. Also had the 35mm/19mm set-up too. Like it also, just wanted to step it up a bit and lose some weight.
Old Jul 4, 2005 | 02:53 AM
DONAIMIAN's Avatar
I think its a part number somewhere where you can get the hotchkis(sp) front bar only.
Old Jul 4, 2005 | 03:07 AM
DONAIMIAN's Avatar
http://frrax.com/rrforum/index.php?a...&hl=hotchkiss&
There ya go, both that bar and the stranno bar are top notch quality, cant go wrong wtih either one.
