Clunking Noise!!!??!!
Old Jul 7, 2005 | 12:15 PM
XTINCT's Avatar
Default Clunking Noise!!!??!!
I Have A 98 T/a M6 And Have A Clunking Noise Coming From The Driver's Side Front Tire/brake Area. The Only Time I Hear It Is When I Step On The Brakes And Am Close To Stopping!!! Any Ideas???
Old Jul 7, 2005 | 09:20 PM
Reject's Avatar
I have a smiliar problam and got a queston too, when im driving the front driver disc/pad assembly wobbles making a clanking sound only when its goin over ruffer area's, but stops when you press on teh brake pedal, i was wondering if anyone had this same problem, need help i already replaced the rotor and pad with new oem kind (to poor to afford the GOOD stuff)
Old Jul 8, 2005 | 03:07 AM
black00TA's Avatar
may check out the wheel bearings, also thuroughly inspect the front suspension all ball joints and tie rods.
then i would check the brakes out.
Old Jul 8, 2005 | 08:45 PM
Reject's Avatar
what will i be looking for inspecting the ball bearings, will i be looking for like grinded metal?
