problems with ADJ Panhard
Old Jul 8, 2005 | 07:29 PM
96blackz28's Avatar
Default problems with ADJ Panhard
Ok so I got a UMI performance adjustable panhard. I had my entire rearend out to clean it up and I had lots of stuff to put on. I put everything back on.. LCA, Springs, Shocks, torq arm, drive shaft.
Heres the problem...
My rearend is off by about 3/4inch to one side. And I cant get the rearend to move the other 3/4 inch to set the adjustment. Are you supposed to loosen something inorder for the rearend to sway left to right a little bit?
Old Jul 8, 2005 | 08:23 PM
mitchntx's Avatar
Put a floor jack under the diff and drag it over.
Old Jul 8, 2005 | 10:13 PM
NoTicketsPlease's Avatar
Ive had to pull on the wheel to get it lined up. Ive heard of people having someone else push the wheel from outside, just be careful.
Old Jul 8, 2005 | 11:42 PM
96blackz28's Avatar
yea my entire car is up on jack stands right now. The rearend is hanging freely. Believe me I've tried pushing on the wheels and it will barely budge. I dunno wtf is wrong
Old Jul 9, 2005 | 12:48 AM
OldeSkool's Avatar
try using a long pipe or something and prying Put it up the back side of the wheel with the end up in the wheel well and pry the wheel towards you. Just a thought.
Old Jul 9, 2005 | 01:51 PM
96blackz28's Avatar
Ok i finally got it all done. I had my dad sit down and put his back againest a wall and push the rearend with his feet while I put the PanHard bolt in. lol
Old Jul 9, 2005 | 02:11 PM
davered00ss's Avatar
Moderator
Are your LCA's Adjustable? Try to install the Panhard then make adjustments with the nut.
