Lowering springs - help!!!
Old Jul 18, 2005 | 09:14 PM
1gen's Avatar
Question Lowering springs - help!!!
Replaced original springs with EIBACH Springs (Pro Kit). Everything is put in right and took it to a shop and they said it was fine. Also, replaced lower left ball joint (driver side). Getting a squeeking noise and knocking noise when go over bumps. Everything feels tight and doesn't pull. Anybody have any suggestions?
Thanks.
Old Jul 18, 2005 | 09:59 PM
OneMeanZ's Avatar
Mine is did that after my lowering spring install, I think my struts are bottoming out. I ordered some Bilstein HDs to hopefully fix this problem.
Old Jul 19, 2005 | 12:37 AM
1gen's Avatar
thanks. Any clue to the squeeking? also I love your quote about skip shift I hate that ****, even if I try to cooperate with it it's so damn hard to get into third like that
Old Jul 19, 2005 | 08:13 AM
01 Red WS6's Avatar
Check the bolt on the strut. It might not be tight, there are a few here that have had squeeking and their bolt just wasn't tight enough
Old Jul 19, 2005 | 10:02 AM
bearcatpride's Avatar
I was having this same problem, then installed Bilstein HD's on all 4 corners and the problem has disappeared
