Good shocks/struts?????
Old Jul 19, 2005 | 05:43 PM
OneMeanZ's Avatar
Default Good shocks/struts?????
I've been reading around and I need new front struts in a bad way. From what I've seen the number one choice is Koni's. But what are some other really good struts/shocks??
Old Jul 19, 2005 | 05:44 PM
Cal's Avatar
Cal
Your car has only shocks, not struts. If you don't want to put up the coin for Konis, Bilsteins are the next best.
Old Jul 19, 2005 | 06:11 PM
OneMeanZ's Avatar
Thanks Cal, I think I might just suck it up and spend the dough on the Koni's.
My car is making a clanking/banging noise like the shocks in the front are bottoming out. I have Advanced Auto Monore shocks in the front now, had to have something to put in there because I mutalated my stock ones.
Will putting Koni's on fix this problem?
Old Jul 19, 2005 | 06:17 PM
Cal's Avatar
Cal
Looks like you may have a lowered car. That's probably what mutalated your shocks. In this case, Konis will definitely last longer.
Old Jul 19, 2005 | 07:10 PM
OneMeanZ's Avatar
Cal, are these the Konis I need to order??
http://www.jegs.com/cgi-bin/ncommerc...09&prmenbr=361
Old Jul 19, 2005 | 07:30 PM
ZaneO's Avatar
Konis are definitely the way to go being lowered...you could also do the revalved Bilsteins...or regular Bilstein HDs as a very last option.
Old Jul 19, 2005 | 07:44 PM
OneMeanZ's Avatar
Thanks Zane O, that link I posted are those the Koni's I need to order?
Old Jul 19, 2005 | 07:56 PM
Cal's Avatar
Cal
Yes, that's the part for Koni single-adjustables. That's what you want.
 Michael S. Palmer
Old Jul 19, 2005 | 07:59 PM
Cal's Avatar
Cal
Here they are on the Koni web site:
[http://www.koni-na.com/display.cfm?m...bmit=Continue]
Just be sure to get the type for 1993 and newer Camaros.
Old Jul 19, 2005 | 08:01 PM
OneMeanZ's Avatar
8241-1139SP Koni front shocks have been ordered....
Old Jul 19, 2005 | 08:02 PM
OneMeanZ's Avatar
My recipet from Jegs looked like this
"Koni Sport Series Shocks 1982-02 Camaro/Firebird - Front Sport Series Strut,
*1993-02 Camaro/Firebird
Item # 610-8241-1139SP"
Old Jul 19, 2005 | 08:04 PM
Cal's Avatar
Cal
Good work! Now when you get them, you might try about 50% full stiffness for the front and about 20% for the rear. That should give you a decent ride and awesome handling. Those are just starting settings though, you can still fine tune from there.
Old Jul 19, 2005 | 09:35 PM
ZaneO's Avatar
GREAT choice.
Old Jul 20, 2005 | 11:08 AM
1gen's Avatar
how much did they cost you?
Old Jul 20, 2005 | 04:54 PM
OneMeanZ's Avatar
492.96 with 2nd business day shipping from Jegs.
