Installing Spohn TA
Old Jul 23, 2005 | 07:30 PM
SVC707's Avatar
Default Installing Spohn TA
I have the SLP subframe connectors and it calls to place the g load brace between the slp brackets and the chassis of vehicle.
do i have to explain how it is physically not possible with what i have in these pictures
Old Jul 23, 2005 | 09:28 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
Just bolt it over the subframes. You might need longer bolts, but it should be ok. If it makes you feel better call Spohn, they will tell you the same.
Old Jul 23, 2005 | 09:29 PM
OldeSkool's Avatar
that's pretty slick
whatcha gonna do? put it on top of the sfc's? If those are bolt in sfc's maybe its time to sell em and get some weld in non-diamond sfc's
Old Jul 23, 2005 | 09:41 PM
SVC707's Avatar
i went ahead and bolted them up after the sfc's. i already have the longer bolts, 35mm.
if i had welded sfc's id be in more trouble as i woundt be able to remove them to put the g load brace in between in spohn sends me the correct one later
Old Jul 24, 2005 | 01:02 AM
SVC707's Avatar
and yes it sits pretty damn low be it i have the one for long tubes but i thinking i couldve got away with the regular ones. ive got alot of space but oh well.
