Possible subframe problem
Old Jul 30, 2005 | 12:06 AM
XpEdItIoUs's Avatar
Default Possible subframe problem
I have some Bmr boxed subframe connectors and the driver side touches the bottom of the floor panel is this normal or should there be clearence.
Old Jul 30, 2005 | 02:25 AM
DONAIMIAN's Avatar
It shouldnt cause a problem. I think with the Spohns they were designed to tuck tight with the floor board so you could run bead the length of the connector if you wanted to.
