Bushings...
Old Aug 11, 2005 | 12:14 AM
OldeSkool's Avatar
Default Bushings...
Wanting to make my own LCA's and PHB.
I want a smooth ride.
Poly/poly is too harsh and binds.
So It'll either be rubber/rubber or rubber/rod
Assuming i buy quality rod ends, will rubber/rod be noticeably harsher than rubber/rubber?
How long can I expect those heavy duty qa1's to last before they loosen up and start clunking?
Old Aug 11, 2005 | 12:19 AM
pimpmaro's Avatar
I doubt you'll notice them with rubber/rod and it would be better than rubber/rubber. FYI, with the high quality QA1 rod ends, I don't notice my PHB at all. Now if you're going to build rubber/rubber... why even bother?
Old Aug 11, 2005 | 12:30 AM
OldeSkool's Avatar
well the rubber deals i am looking at are a bit stiffer than stock, but my main goal is replacing the stampings with lighter/stronger aluminum and gaining adjustability (thrust angle correction) and centering the rear for 315's and lowering.
Old Aug 11, 2005 | 04:22 AM
DONAIMIAN's Avatar
Go high quality rod ends, or just dont even bother.
