front shock spring assembly explodes !!! need some help
Old Aug 13, 2005 | 03:42 PM
Dave Carney's Avatar
Thumbs down front shock spring assembly explodes !!! need some help
I just finished putting a new bilstein in the coil and perch assembly, had the spring compressors completely off except for one of the grips at the end which was stuck between the coils, as I attempted to maneuver it off, the whole thing exploded!!!!! the spring shot up in the air...wow...pretty scary...anyway...what happened was the spring perch (upper mount) is just rotten I guess and the area around the rod hole just tore away! So now I have a worthless mount, with a big honkin' hole in it and I suppose this is a dealer only part.....anybody bought one elsewhere? Part# 17999215 LH but i'll be picking up the RH too after this.
Old Aug 13, 2005 | 03:59 PM
mitchntx's Avatar
I bought a pair from O'Reilly's last year.
Old Aug 13, 2005 | 05:25 PM
Mitch, thands for that key piece of information. I found a set at O'reilly. Thanks again!
Old Aug 13, 2005 | 09:39 PM
DONAIMIAN's Avatar
leave it open, might come in handy for someone else if they decide to use the search button.
Old Aug 13, 2005 | 10:06 PM
trackbird's Avatar
Tire Rack has (or at least they did the last time I looked) the mounts as well.
Old Aug 13, 2005 | 11:14 PM
On the other side the mount fell apart when I tried to remove it. If any of you guys are doing front front shocks on a car that has some miles on it, i'd just buy the new mounts and have them ready to go, same as sway bar links......I've never seen such a bunch of rusted bolts nuts, and worn out rubber...what a mess, I had to cut the shock nut off the deCarbon and then cut the metal sleeve off that tore away from the mount..
The mounts aren't cheap btw, $55 to $70 a piece depending on where you get them.
Old Aug 16, 2005 | 11:23 PM
JonB's Avatar
I had to get one from a junk yard can't rememeber what i paid. The only place i found one was at the dealer and they said it only came with the upper control arm and they wanted some outragous(sp) price like $300+. Unforutantly I don't have an O'reilly around me.
