trac lock
Old Aug 16, 2005 | 07:21 PM
32V SVT's Avatar
Default trac lock
My fianace has an automatic 2002 trans am ws-6 and i think the trac lock is out in it.While on the lift both tires spin different directions i tried to load one tire while idling in drive and the other just seemed to spin faster. Is there another way to check this with out pulling the cover or is this just normal.I have not tried to burn them down to see if it leaves two black marks.
Old Aug 16, 2005 | 08:16 PM
jaberwaki's Avatar
best way to check is still to light em up, if the posi is shot you will get the one tire fire..
Old Aug 17, 2005 | 06:27 AM
99FormulaM6's Avatar
yep, looks for a one wheel wonder
Old Aug 17, 2005 | 07:29 AM
777's Avatar
777
You can't just spin them to test it. The whole idea of a posi is to be able to go around corners (one wheel turns faster than the other) without it locking the tires together. Just go and light `em up.
Old Aug 17, 2005 | 04:44 PM
demonspeed's Avatar
It's not mine! woo hoo!
The fbody doesn't have a Trac Lok diff like the Mustang. What I mean is, whereas the Mustang uses clutch packs to engage the limited slip, the fbody uses gears. Keep this in mind.
Old Aug 17, 2005 | 04:49 PM
Black99TransAm's Avatar
when you punch it around a turn can it burn one whell or should it spin both. it depends how i take a turn sometimes it burns both and other times it will spin one. when i do a burnout it spins both with 2 black even lenth patches of rubber. it doesnt make any noise at all either. is this normal for a posi to do
