Probably a Dumb Question...
Old Sep 6, 2005 | 01:42 AM
mnc2886's Avatar
Default Probably a Dumb Question...
This is probably stupid, but if I buy the complete QA1 set up, can I set the ride height to the equivalent of a 1" or 1.5" drop? I didn't know if the ride height was adjustable as well as the stiffness. Thanks for answering the dumb question in advance. If it matters, my springs and shocks are totally stock.
Old Sep 6, 2005 | 02:28 AM
JustAnIlluzion's Avatar
no its not that easy. u have to get coil overs to do that. not a stupid question.
Old Sep 6, 2005 | 02:53 AM
mnc2886's Avatar
Where do I get coil overs?
Old Sep 6, 2005 | 04:40 PM
DONAIMIAN's Avatar
The front QA1's are a coil over. You have the buy the BMR springs perches so you can use a stock type F-body spring.
Old Sep 11, 2005 | 02:11 AM
JasonWW's Avatar
The front QA1'a are fully adjustable in ride height, You can adjust it by the mm. if you want.
You'll need some kind of new adjustable setup in the rear to adjust that end. Ground Control sells a rear spring kit that's adjustable for $200.
