spring installed wrong
Old Sep 6, 2005 | 10:15 AM
Vertigo's Avatar
Default spring installed wrong
After listening to my rear clunk around as if it had no springs whatsoever I decided it was time to take a look. Low and behold I found that the passenger spring was installed 180*. After twisting it back around and taking it out for a test drive it absolutely helped (not totally fixed, LCA's are bad) my problem. I didn't know that the direction the spring is facing made so much difference!
Old Sep 11, 2005 | 02:37 AM
JasonWW's Avatar
Yea, the factory recommends that the lower pigtails be pointing to the drivers side. Rotating them should effect the ride height slightly, but I don't know why your car made noise.
