launch pics, pre/post torque arm
Old Sep 8, 2005 | 01:38 PM
slayer_taunu's Avatar
Default launch pics, pre/post torque arm
*crossposted in drag racing tech*
here are pics of my launches before and after adding the headers, torque arm (set to -1 deg), and dyno tune. there were a few pics from each day, so i picked the best one from each.
it looks like i gained a good inch of weight transfer (of course its always possible that its just the timing of the photos). too bad i'm not gonna really see that gain on the street tires though, since my 60' didn't change at all...
Old Sep 9, 2005 | 07:18 PM
Zymosis's Avatar
Now if your tires were off the ground an inch, id be impressed
It does look like your launch was better. The stock torque arm robs quite a bit of power, so any change is a good change.
Old Sep 24, 2005 | 02:26 PM
i'm gonna try removing the front sway bar and see how much of a difference that makes
Old Sep 24, 2005 | 07:16 PM
Bad Blu Formula's Avatar
You need to be running faster than a 13.2 if thats an updated time.
Old Sep 24, 2005 | 07:29 PM
Krab's Avatar
Careful with that 10-bolt.
Old Sep 25, 2005 | 10:47 AM
yes, that is an updated time. i only ran one night since setting up this combo, so i need more track time. i believe my most significant flaw is making street tires hook... i just haven't figured out how to launch with the M6 yet. i'm there is also some time robbed from my shifting technique as well, but i'm more concerned about reducing that 2.2s 60' time.
