noise due to lowering
Old Sep 20, 2005 | 02:39 PM
nascarnut3n8's Avatar
Default noise due to lowering
i lowered my 00 ss using dms springs and kyb agx struts/shocks after the install i had it aligned. the front end is making a popping sound it mostly does it while turning in reverse what can be causing this
Old Sep 22, 2005 | 02:30 PM
LTorres's Avatar
Does the noise change pace with wheel rotation? The key here is to isolate the issue. Can you tell if it is more center, front/rear or Driver side passenger side? Help me with these questions and I'll try to point you in the right direction. I have worked in Brakes, Suspension and Alignment for over 10 yrs.
Old Sep 22, 2005 | 03:52 PM
Bad Blu Formula's Avatar
Check if your tires are rubbing or if the strut tower nuts are loose.
Old Sep 22, 2005 | 11:31 PM
joblo1978's Avatar
Are you rubbing the wheel well splash guard?
