brake problem
Old Oct 3, 2005 | 10:41 PM
rbobryk20's Avatar
Default brake problem
I recently upgraded to LS1 front brakes on my 94 z28. I put brand new calipers/pads/fluid in. Now when i press the brakes it is rather squishy and after pumping 2-3 times i can build pressure. I thought i bled them pleanty but maybe not. Could this be the problem or is it possible there is a leak somewhere and air is getting into my braking system?
Old Oct 9, 2005 | 02:42 PM
JasonWW's Avatar
How did you put new fluid in? A pressure bleeder?
Your problem sounds like a simple case of air still in the lines.
