Wheel spin
Old Oct 7, 2005 | 05:24 PM
Shutout's Avatar
Default Wheel spin
What would be the best way to control wheel spin? I just recently installed UMI LCA's to get rid of my wheel hop (which it did) only now to have alot of wheel spin. When I punch it from a roll (10 mph) the car hooks up "ok" but when I hit about 3500 to 4000 rpm the car kicks sideways and smokes the tires before the traction control kicks in and/or I let off the gas. Would a PHR and SFC fix this problem?
Old Oct 7, 2005 | 10:06 PM
boostedtransam's Avatar
a torque arm will help alot..
Old Oct 7, 2005 | 10:23 PM
Lights_Out's Avatar
I have to 2nd that!!! A torque will help alot!!
Old Oct 8, 2005 | 07:12 AM
nostyta's Avatar
Well a torque arm will help alot, also if your car has been lowered a set lca relocation brackets will help, you may also want to look into getting a good set of shocks to help plant the rear. As for your qeustion -- a panhard rod is used to help keep the rearend centered and sfc want help much with traction.
