Brake Fade . . .
Do the stock brakes suck that much????? I have driven the car on that road before and pushed it just as hard with no brake fade. I recently changed the front rotors, front pads, surfaced the rear rotors and rear pads. Or do I have a more serious problem?
And, yes, the stock pads do suck for that kind of use.
...run a thread search here for "bleed brakes"
I suggest you buy a bleeding tool that makes the job much easier. The trick here is to NOT get any air into the brake lines. If you do, the job becomes a real PITA.
I didn't come here to lecture, I came to help you with your problem. But a flippant response with the
can be enough to get me started.....When I was 21, I was young and invincible too. I'm amazed that I didn't kill me or someone else with the crap I pulled back then. I hope your as lucky as I am.
Be careful out there guys....and that means everyone.
If you have never bleed a set of brakes before, I would really suggest that you find someone who knows how to help you through the first time. DO NOT get air into the ABS module buy running the reservoir out of fluid.
