Strano 22mm Rear Swaybar and Moser 12-Bolt?
Will the Strano 22mm rear swaybar work with a Moser 12-bolt? I know the Strano bars come with frame mounting brackets, but will there also be a need for relocation brackets? If so, BMR makes one for the 1LE 21mm, and Spohn makes one as well, but will either work?
Thanks.
Thanks.
LS1TECH Sponsor
I wish I could tell you..... I'm pretty sure I have customers out there with 12-bolts and that bar one, but I don't know if it just popped on or not. The bar is designed for the stock 10-bolt, and was reported to me, I beleive last week, that it actually had more room around the pumpkin than a GM 21mm bar (that was a 9" car, but more room is more room). Obviously any kit that uses busnings other than 22mm won't work, but the bar comes with new bushings so really *if* you need a adapter kit for your 12-bolt, you would need only the bracket mounts for your axle tube.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
