Caliper Bolt Torquing.
Old Oct 22, 2005 | 04:25 PM
SlowBurn's Avatar
Default Caliper Bolt Torquing.
I'm about to replace my front stock pads/rotors with Brembo Blanks and Hawk HPS pads. It has been a long while since I have changed brakes on anything (this is my first car in about 3 years). When I replace the rotors what should I torque everything back up to? Same with the caliper bolts. Everything else from what I remember is just a matter of swapping out the stock pads and putting a little brake quiet on the metal side of the pad that comes in contact with the piston right?
Old Oct 22, 2005 | 05:03 PM
8-Pack's Avatar
Caliper frame bolts are 74ft-lbs and the caliper boltsm are 23 ft-lbs. http://www.installuniversity.com/ins...sity/index.htm, Pretty good write up so you can see everything involved. Replacing pads and rotors are along the same lines as an oil change, difficulty wise.
