Help with spring question???
Old Nov 9, 2005 | 03:04 PM
RAC 4 FUN's Avatar
Default Help with spring question???
I have Eibach lowering springs on my 2002 Z. My question is...can you run the stock height spring in the back and the Eibach up front? I am trying to achieve a little rake to the stance without going to air bags. Also need more clearance for a bigger drag radial. Any thoughts??
Old Nov 10, 2005 | 01:56 AM
YellowToy/A's Avatar
That is alot of front spring rate for a drag car. You can run any springs u want in the back. With what u have in the front the back will roll more that the front. But that should not be a problem with a drag car on the street. My friend runs no sway bar in the front of his car. If you do that it may be more balanced. Just remimber a drag car is backward from a car that handles. It is very hard to build a car to do both
Old Nov 10, 2005 | 03:08 PM
dailydriver's Avatar
Unless it's a C5/C6 Vette!!
Old Nov 10, 2005 | 04:54 PM
Viper's Avatar
You can run the stock spring in the rear, however I didn't like how it handled at all with that combo. I run a 3rd gen Bilstein in the rear for shocks FWIW.
