Toe setting - How, not how much question.
Question:
I'm going to mark the tie rods so I can get back to 0. How much should I change each tie rod to get about 1/16" toe out? I guess what I'm asking is how much will each quarter turn on the tie rod change the toe?
Also, which way do I spin it to make the tie rod longer?
To answer the question you didn't ask, IMO you are better off leaving it at zero toe, or better yet checking it and making sure that's what it is really set to. Toe out will mess up your Ackermann (make the inside tire skid on turns) and is not really needed on a fbody with good race tires IMO. If you are using weener cheap street tires with soft side walls, then OK, but you will want to set it back to zero after the race day. I think it is best to get some good road race tires with stiff sidewalls so you don't need toe out to make the car turn.
Toe adjustments won't reduce understeer anyway; might even make it worse. Maxing out the available negative camber is an alignment adjustment that really will reduce understeer. Another thing that will help is a bigger rear swaybar, but don't go too big or the car will be tail happy.
