Need some advice & pics
Old Nov 10, 2005 | 08:49 PM
Fad2blk_98's Avatar
Default Need some advice & pics
The bolt hole for the torque arm mount in the tranny got stripped somehow, and my torque arm came out. I can not get the bolt back in to hold now because it's stripped. So I am looking to get a body mounted torque arm to fix this and get better performance.
Question is, I have a lowered car with Eibach pro kit and need some advice on which one is best to use for clearance, as well as some pics if possible with torque arms and lowered cars. I'm looking to get this here soon, so the more help I get the better. Any advice greatly appreciated.
Here are a couple pics of how it sits:
Old Nov 10, 2005 | 11:20 PM
Xtnct00WS6's Avatar
Isn't there just one of the three bolts that actually screws into the tranny? The other 2 slide through the clam shell thing and have nuts on the end. Couldn't you just retap the threads for the one bolt that gets screwed in, if that is in fact the bolt hole that got stripped?
I guess you'd have to pull the tranny to retap the threads of that one bolt hole, but I'm gonna guess that you're gonna have problems with a non tranny mounted T/A. Your car sits quite low. Looks sweet tho! If you do pull the tranny, it'd be a good excuse to upgrade the internals
Old Nov 11, 2005 | 12:20 AM
Fad2blk_98's Avatar
To be honest, I'm not sure if there are 3 bolts. I only seen/felt one and so did a friend of mine. And yes I'd have to retap the threads, and trying to avoid that since I'd have to pull the tranny. I would rather go with something stronger IF I can get away with it which is why I'm asking opinions.
Thx for the reply and compliment on the bird
Old Nov 11, 2005 | 12:57 AM
Korben's Avatar
Spohn torque arm will work fine on your car, you will have to use the big ******* hammer mod on the tunnel a little bit or else you will get some banging from it........
Old Nov 11, 2005 | 01:13 AM
Fad2blk_98's Avatar
I had read some on that mod with the Spohn T/A What about the BMR Trac Pac (I think that's what it was)?
Old Nov 11, 2005 | 01:48 PM
Fad2blk_98's Avatar
Any other opinions on this one?
Old Nov 11, 2005 | 08:23 PM
Fad2blk_98's Avatar
Really needing some more input on this. I know there are a lot of guys with aftermarket T/A's on here, so please post some pics and/or opinions on which I should use. Thank you.
