Question about Bilsteins
Many will say HD's are fine for lowering springs. Fine, but Bilstein doesn't think so aside from what I think (and I agree having driven many cars like that).
And this statement is almost 100% incorrect: "slp bistiens are for a lowered car they were made to be matched with a eibach 1" drop spring" They are valved for SLP springs that happen to be made by Eibach, but are in no way similar to any of Eibach's aftermarket rates. And they also are not 1" lower, but supposedly about 3/4" and often times not even that. SLP Bilstein's are designed for SLP springs. And as a package are ok performing (about what I think should have been OEM and not optional), but nothing remarkable. Still tuned with comfort and a bit better performance.
Strano Revalves are just what Judd said.. Reworked case by case to match the spring YOU HAVE. Bob with Pro-kits doesn't get what Frank with Hotchkis springs get, and so on. Each spring rate is different in the way they are wound, how soft and stiff they get, and each person has different parts and expectations as well.
If you want to put on a non-adjustable shock vs. say a Koni that can be tweaked to do whatever, then you should use a damper that's tuned for your needs. How many of you put a big cam in a car with stock heads and valve springs? You could, but how smart would that be? Same issue here.
