need spring expert
Old Nov 24, 2005 | 09:57 PM
todd4168's Avatar
Default need spring expert
I had bmr springs on my car with stock shocks and it was just too much beating the crap out of my exhaust. I bought a set of springs on ebay for a ws6 trans am 2001 and had them put on at a local mechanic. I didnt notice till I got home but the drivers rear is about 2 inces higher than the passenger side. Any comments on what went wrong? Thanks It never stops!!!!!!!!!!!!!Always something.
Old Nov 24, 2005 | 10:43 PM
peterlawl84's Avatar
you just bought bad springs, my springs were like that and i bought a set of eibachs which went out like that after two years
had to buy a new set a couple months ago.
sorry man
Old Nov 25, 2005 | 01:35 AM
Cal's Avatar
Cal
If you look up inside the spring buckets, you will see there is a depression in the middle that is supposed to be centered in the spring. If it is not, you can have this problem. So check that before you buy springs again. Also make sure the pigtail on each spring is oriented the same way.
