What is the problem with my brakes?
I'm not sure what the problem is here. Brake fluid is fine. The only thing I can think of, and others have suggested, is that somehow my warped rotors are contributing to this. I've made a few passes at the track on stock rotors and i'm sure they are warping. But it doesn't sound like an ABS issue.
Any other suggestions what would be causing the popping in the pedal? or the lack of braking power?
Thanks.
Thanks.
I would pop off a fromt wheel and have a look at the pads on one side. Take longer to get the car in the air and wheel off then to get the pads out to inspect.
How many miles do you have on the front brakes?
Make sure that the caliper slide pins move freely and are not seized. If so, take the old pins out, clean out the holes, buy a new pin set and lube, and put it back together.
As far as the ABS is concerned I really have never heard of ABS acting in this manner. Of course if that's how it operates then I suppose I will learn to live with it. It's just a tad scary when trying to brake from high speeds.
I will go out and check my slide pins.
Thank you again Lethl_SS & 2000 TAWS6
