sway bars
Old Dec 24, 2005 | 09:17 PM
1999 SS's Avatar
Default sway bars
i recently bought front & rear BMR sway bars solid front hollow rear 32mm/22mm for my camaro but have been hearing that the 35mm strano hallow front would be a better choice than tha solid BMR front. what do you guys think?
what if i put the BMR solid on the front of my stock suspension 00 ta. how would it affect handeling if it has the stock 19mm rear sway bar and oem shocks?
Old Dec 24, 2005 | 10:18 PM
OldeSkool's Avatar
Despite BMR's advertising claim... the 32mm solid bar is not much stiffer than the stock bar (according to the stiffness calculator). Solid really only makes for a heavier bar, not a stiffer one... Larger diameter makes for a stiffer bar... Also.. while many like to buy front and back all at once thinking that it will keep the car balanced, this may not be the best way to do it. I suggest upping the front bar and then see whether you want the back too... most times, 22 is too large for the rear.
Old Dec 24, 2005 | 10:33 PM
CamdLs1's Avatar
32mm is an upgrade from stock (unless its an SS w/ suspension options or WS6) but 35mm is definitely better. I have a 35mm solid w/ a stock rear bar. Its still a good combo but I am gonna get a 21mm-22mm bar soon. Go with the strano bar.
