Just installed a STB....
Old Jan 2, 2006 | 11:58 AM
Red97Z's Avatar
Default Just installed a STB....
Ok, I just installed a BMR STB, and after trying to find a wrench small enough, a 15mm socket small enough to clear my brake lines, it seems as if the STB is resting on a very slim piece of metal thats on the inner fender/strut tower right to the left of the 2 bolts. This is preventing the STB from resting perfectly flush with the metal mounting position. I just want to know if anyones ever encountered this, and whether this should be a cause for concern. I'll get a pic up to help better explain it. It's bolted down pretty tight, so I doubt it should move or be a problem, but i'd just like to make sure.
Old Jan 2, 2006 | 02:04 PM
Red97Z's Avatar
anyone
Old Jan 2, 2006 | 02:09 PM
patSS/00's Avatar
I was also concerned about this, way back when I got my BMR STB. I made a couple of flat metal pieces that fit between the STB mounting points and the chassis, so it was flush.
Old Jan 2, 2006 | 02:10 PM
patSS/00's Avatar
By the way what happened to the 2nd stud?
Old Jan 2, 2006 | 03:02 PM
02blackws679ta's Avatar
every car has that...and its not big deal. the STB isnt going to "do" anything for you anyway and that thin peice of metal isnt hurting anything.
Old Jan 2, 2006 | 04:50 PM
Red97Z's Avatar
the 2nd stud is actually behind the ac line. thanks a lot for the info!
