when i brake, pulls left
Old Jan 2, 2006 | 09:19 PM
rollinenvy's Avatar
Default when i brake, pulls left
when i brake my car jerks right, more so at slow speeds then at high but it still does it.. what is the cause......?
Old Jan 2, 2006 | 11:14 PM
blue01ta's Avatar
One side is probably grabbing harder than the other. Or one side isn't working. Your title says it's pulling left your post says it's pulling right.
Old Jan 2, 2006 | 11:55 PM
Foxxtron's Avatar
Assuming that your brake system itself is okay, your alignment might be off, specifically toe. You should get your alignment inspected and adjusted properly.
Old Jan 3, 2006 | 02:45 PM
QWIKWS6's Avatar
My car does the exact same thing. It pull right under braking, even more at low speeds. It needs a brake job soon so im gonna see if that fixes it...
Old Jan 19, 2006 | 02:47 PM
Roadhouse's Avatar
It could be that the flexible brake line to the LEFT front caliper has failed since your car goes to the right upon braking. I had a '87 monte carlo that developed that problem, when I would apply the brakes the car would dart to one direction and when I release the brakes it would turn itself the other way. It turned out a flexible brake line had collapsed internally causing a restriction of fluid in either direction of flow. It also could be a stuck piston in the left caliper.
