Look what I got in the mail.
Old Jan 10, 2006 | 10:06 PM
Shamson5.7's Avatar
Default Look what I got in the mail.
This is going in tomorrow morning. Cant wait especially since my stock TA is currently doing a twizzler impression.
Attached Thumbnails Look what I got in the mail.-resize-rotation-imgp0205.jpg
Old Jan 11, 2006 | 12:44 AM
1999Z28's Avatar
good luck...i will say the biggest pain is getting the transmission side installed is the biggest pain...it was soo hard to get that clamp closed on it
Old Jan 11, 2006 | 02:30 PM
98boxer's Avatar
I thought I was the only one who suffered getting the bracket to close. I swapted in poly bushing and had to take off the whole ta and it was a pain to get the ta bracket to close. Once I got that done or before don't remember in which order.I remember also to make sure you keep the 10 bolt alighned if not when you install the ta you will have to use a jack to raise or lower the rear end so the hole can line up to ta holes with the rear holes to put the bolt in. I know for my car when I put in poly bushings it was well worth the upgrade and later on I will be putting in a new ta.
Old Jan 11, 2006 | 02:49 PM
Shamson5.7's Avatar
I got it installed no problem. I really dont understand why people say they make so much noise? I actually thought it was a tad quieter since I got it.
Old Jan 11, 2006 | 02:53 PM
ssPetess's Avatar
The chasis mount units are the noisey ones... I have the same one as you and I have no noise issues either. Did you remove your rear springs during the install?
Old Jan 11, 2006 | 02:58 PM
Shamson5.7's Avatar
I had access to a lift. No need to take the springs off.
Old Jan 11, 2006 | 04:10 PM
BitViper's Avatar
Thats a really big fish you got there boss!
