Need to replace calipers when rotors go bad?
But the guy told me that I might have to replace the caliper as well? Doesnt sound right...
I guess if the rotors you are looking at don't say that, you might should ask somebody who knows more than I do. =p
Now, in your case, make sure all your dust boots are good. Also, make sure the piston slides freely in its bore. You should be good to go. With the info you posted, I'd recommend taking your car somewhere else.
There is really only one reason to replace a brake caliper.... When the caliper is frozen, as in the piston no longer slides in its bore. In this case, you can rebuild it. But in most cases, a new/rebuilt caliper is relatively cheap.
