Replacing bushings
Old Jan 17, 2006 | 11:34 PM
robertbartsch's Avatar
Default Replacing bushings
I will be replacing some worn shocks soon. Is it worth it to replace all the upper/lower control arm bushing with poly?
Do I need any special tools or do the old bushings just pop out?
Old Jan 19, 2006 | 10:03 AM
asudecat's Avatar
It's quite a job to do.
I burned mine out. There is also a sleeve you will need to press out from the lower A arms. They are about to go back on the car so I dont know how they will work out yet. But Im sure it will be a nice difference.
Old Jan 19, 2006 | 02:07 PM
98boxer's Avatar
I replaced the rear lower control arms and I highly recommned you buy aftermarket lower control arms. I bought the poly bushing for 50 bucks plus another 50 bucks to take it to a shop to get the bushing out/in. I've seen aftermarket lca for 100 bucks. Their is a noticable differece, not a big difference but noticable. Installing the rear lca is not problem.
Old Jan 19, 2006 | 07:54 PM
OK - So you can't push out the old front lower control arm bushing with a couple of large sockets and a big vice?
That blows.
Replaceing the top control bushings is not diffucult and you don't need to "press" them out; right?
Thanks...
Old Jan 19, 2006 | 09:29 PM
asudecat's Avatar
all I can tell you is to go ahead and try it. It might work for you. We just went ahead and burned them out. But dont forget to press the sleeve out on the lower a arms.
