Creaking in rear
My car creaks in the rear almost any point during movement, it's worse over bumps or pulling into driveways, but you can hear it when you just begin to accelerate and the rear end squats a little.
I've tried putting lithium grease on every bushing I could find, and it didn't help. The only thing I can think of at this point would be shocks (98 model with 101k on it, stock suspension).
Am I missing something obvious?
The spare and everything is tightened down, I'm almost certain it's the suspension. I moved the car around a bit while laying under it and it sounded most audible from the passenger side wheel. I think I will try greasing the sway bar bushings up tomorrow to see if it helps any.
I guess for what it's worth, you don't really have to pull the swaybar off, but I did. It would probably be easier not to.
