Alignemnt Specs?
Old Jan 26, 2006 | 02:54 AM
nikeboy313's Avatar
Default Alignemnt Specs?
I just lowered my car with LG Motorsports G2 springs and Bilstein HD's and i need some good alignment specs to make this car handle... Thanks in advance
Old Jan 26, 2006 | 01:09 PM
nikeboy313's Avatar
to the top
Old Jan 26, 2006 | 02:26 PM
DONAIMIAN's Avatar
I use 0 toe, -.5* camber and 6* of caster. You might not be able to get that much caster...I have no idea how I did, but thats just what I have. Its pretty stable, and its not agressive at all.
Old Jan 28, 2006 | 08:28 PM
mbraun's Avatar
if you are wanting to corner hard i suggest -.7 camber and just a touch of toe out. this will roll into a corner with very neutral handling and not eat the outer edges of the tires. I have mine like that and it works very well and still is on the edge of factory specs. Also since you lowered the car you should get an adjustable phb. Sam Stanos makes a great on with rod ends. To handle well the rear tires need to be directly behind the fronts. Call Sam @stranos autoparts he really knows this stuff
