Abs Inop ???
Old Jan 26, 2006 | 11:13 PM
NW00SS's Avatar
Default Abs Inop ???
Probably the beginning of last summer, I started getting this light on my cluster. I have no idea what tripped it, or how to fix it. I pulled the fuse and put it back and yet it still come up. An ideas? Bad wheel sensor? Knock something loose on top the rear? HELP! I'm sick of the light!
Old Jan 27, 2006 | 09:13 AM
00NBMCamaro's Avatar
the sensor i believe is on the top of the diff on the driver side, mine has only come on once. that was after i dynoed but it went off after a mile or so of driving. good luck
Old Jan 27, 2006 | 10:02 AM
99legnd2rZ's Avatar
Check where it connects to the car. I had the problem after I had trailered my car. I found that I had pulled the wiring harness and plug out from the car.
Old Jan 27, 2006 | 10:59 AM
DONAIMIAN's Avatar
Check the connections, if theyre all tight, then its the wheel speed sensor. I tried everything short of replacing to get it working again, then I took it to mineke(sp) they rest something and it hasnt been on since.
Old Jan 27, 2006 | 11:20 AM
Bowtie Guy's Avatar
Also check the bulbs in your 3rd brake light. I had this problem on my 96.
