centering the rear end
Old Jan 30, 2006 | 05:56 PM
mikey1000rr's Avatar
Default centering the rear end
Well i have the spohn adjustable phb and I adjusted it to the center but I notice today that after driving it the rear end shift to one side or the other what causes it to still move alittle how can I fix it
Old Jan 31, 2006 | 08:35 AM
ssPetess's Avatar
Do you have rod ends? I was surprised to learn just how much the poly bushings flex. Also, are you running too low of tire pressure in the back?
Old Jan 31, 2006 | 11:14 AM
WELL IM RUNNING 28PSI IN THE REAR JUST BUCAUSE i GOT 295 RUN FLATS.WHAT ARE ROD ENDS? ITS THAT THE PROBLEM?
Old Feb 4, 2006 | 02:02 PM
